Oil flow meter
Oil flow meter
Hi guys. Im from Argentina and im looking the key words to find a specific oil flow meter.
We develop an hydraulic circuit that is powered by a tractor. This circuit has 1 pump (70 l x min/18GPM)and two motors. We need to meter the flow (we have 60 bars/ 870 psi aprox, and 60C/140F).
The flow meters I found in amazon work under 20bars and 60c temp (https://www.amazon.com/19-190L-Electronic-Flowmete...).
I dont know how the key words to find the correct meter.
Could you guide me?
Regards!
Could you guide me?
Regards!
RE: Oil flow meter
Use the selection options on the left hand side.
This one will probably work for you:
http://www.omega.com/pptst/FL7100_7300.html
RE: Oil flow meter
Ted
RE: Oil flow meter
