Is it possible to Integrate an external document into Knowledge Fusion Library?
Hi all,
is it actually possible to integrate an external document (e.g word document which contains some requirements) into knowledge fusion Library and then be able to visualise the integrated requirement in NX knowledge fusion?
Let say for example i modeled a KEY and one of the requirement is that the surface of the key should be smooth. Can this kind of requirement be integrated and visualised within the CAD model enviroment or is it only possible to implement this kind of requiremtn when a specific condition like "surface roughness = 2,40 µm" is given?
PS: with the term "visualised within the CAD model enviroment" i mean that when i click on the KEY CAD Model there will be a kind of pop-up window that will show me the requirement that was defined there.
I would also be grateful tif i'm directed to some links where this kind of issue is discussed.
Thanks for your time.
RE: Is it possible to Integrate an external document into Knowledge Fusion Library?
Have a look at HD3D tab under ANT.
It may do the job
Didier Psaltopoulos
http://www.psi-cad.fr
