How long can form oil last on forms?
So the contractor built the form but is unable to pour for a while due to some unforseen conditions. Is there a code stipulation as to how long the form release agent can be on the forms before pouring the concrete?
RE: How long can form oil last on forms?
Dik
If wood, won't last long...a few days at most. if humidity is low....less because the form oil soaks more into wood
If steel, will last a lot longer.
As others note, check manufacturer's info. Will also depend on whether release agent is petroleum based or polymer based
Dik
