ISO standard for showing optional machining on drawings
Is there any standard designation of annotation for optional machining. Like if you can do machining vertical or horizontal and it will leave different tool radius on edge of machined surface. So that radius can be small as it will be mill cutter cutting edge radius (if any) or big if it is mill cutter main radius. In both situations it will be just "left over" from milling it, in X or in Y direction. How to explain this on drawing that is not internal, but have to be delivered to supplier.
_____________________________
Enjoy your work and have fun!
RE: ISO standard for showing optional machining on drawings
Just put the range of acceptable radii on the drawing.
I would use MAX or MIN depending on your requirements instead of a Limit Dim.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
According to the number of parts to fabricate, the machine shop will use the tolerance indicated in your drawing in order to determine what method will be more economic or convenient.
As others have advised, simply specify a max/min radius.
"Engineering is achieving function while avoiding failure." - Henry Petroski
Can somebody tell me what is the ISO standard that explain how to use MAX and MIN?
ISO 129 maybe..
Thanks.
ISO 2692---Maximun material principal and least material requirement.
ISO 129---Dimensioning-General principles, definitions, methods of execution and special indications.
Season
