Maximum concrete masonry lintel/bond-beam span?
Assuming self-weight only, nominal lateral loads, and a deep wall, what's the longest you would ordinarily span a reinforced lintel/bond-beam?
Assume 8 inch 190mm blocks with single layer of reinforcing.
RE: Maximum concrete masonry lintel/bond-beam span?
1) is two or one sided arching action available?
2) where will the nearest control joints be?
In general, I try to stick to a span to depth ratio less than 15.
