Brushless excitation
Even new synchronous machines, specially Rotary Compensators, still use brushes/rings for field winding excitation current instead of brushless system. Probably the possibility of field polarity reversion is the reason.
When/why is this reversion necessary? Thanks.
RE: Brushless excitation
You can't use field forcing to rapidly reduce the field strength on loss of load with brushless systems.
Bill
"Why not the best?"
Jimmy Carter
So, considering the rotary compensator, the field forcing can provide a faster response and a better regulation performance when field weakening becomes necessary. Am I right? Thanks waross.
I believe so but wait for some replies from those with more experience with large machines. I haven't been around field forcing for about 40 years. Some of our other posters will have more knowledge on current practices.
Bill
"Why not the best?"
Jimmy Carter
A slipring machine can have a faster response because one of the R-L time constants is eliminated in the rotating exciter, and because the slipring machine can, when provided with a four-quadrant rectifier fed from a suitable supply, actively suppress the field by regenerating into the source.
waross and SkottyUK.thanks. Simple and direct as your answers.
I don't even think that you need a 4Q supply. That would be if you need to reverse excitation current. But in this case, all you need is a counter-EMF, which a simple thyristor rectifier can create. But you can not have a free-wheeling diode. Or a half-controlled bridge.
Gunnar Englund
www.gke.org
Basler might have a paper on it. I remember sitting through one of their presentations at one stage on migration from a brushless excitation system to a slipring one. The summary of the whole presentation was effectively what ScottyUK said though.
EDMS Australia
Freddy,
A regenerating generator rotor looks a lot like a current source, so Skogs is right - a fully-controlled bridge will meet the requirement for two quadrant operation. Four quadrant would actually reverse the field polarity, which doesn't happen in practice.
