Wind Loading on Inset Storeys
Hi guys,
For those who are not familiar, the current Eurocode, as far as i am aware, does not provide advice on wind load zones for top floors with inset storeys, such as the whole penthouse theme with terraces etc. Does anyone know the current criteria for calculating the wind pressures in such cases?
Thanks.
RE: Wind Loading on Inset Storeys
Do you worry that it will be higher than if the walls were not inset? If not, then why not use the standard values?
I don't know off hand of anything and have always just used standard wind loading, even on inset storeys.
