About Column Least Dimension
Hello Engineers,
For G+10 storied concrete building is it correct to choose column least dimension 12 in?? Some expert says for 10+ storied rcc building it is best to choose column least dimension 15 in.But my structure says it is satisfied in 12 inch.
N.B.=My column sizes are
(12 in x 30 in)
(12 in x 36 in)
(12 in x 24 in)
Whats your thoughts/comments??
(12 in x 30 in)
(12 in x 36 in)
(12 in x 24 in)
RIFAT
RE: About Column Least Dimension
Also, what is the occupancy?
RIFAT
Because I think those sizes won't satisfy drift requirements.
RIFAT
RIFAT
BA
I'd suspect you'd struggle making 250mm wide columns work, unless you increase the length by a minimum of 4x the width (ie 1000mm).
In saying that you could have a column every 3m... the question really need more info...
