ChechStress For Designers
Hello All,
CheckStress is a stress analysis software that gives a designer a preliminary view of pipe stresses in an effort to send a better model to stress to check. Has anybody here worked with it or with a design department that uses it? Trying to find out if it's any good.
Thanks in advance!
RE: ChechStress For Designers
Never heard of it and more to the point I do not beleive many will use it. Might as well do the stress analysis in the first place if the system is deemed "critical"
DSB123,
Thanks for your reply. I believe it's made by the makers of CAEPIPE. I can't find any info on it, other than info by the makers, so you may be right that not many have/will use it.
