SA312 EFW Pipe in Lethal Service
I've got a small-diameter lethal service vessel per ASME Section VIII Div 1 with a 316SS metallurgy. I called for ASME SA312-TP316 EFW for the shell and nozzles, with 100% RT.
My code gurus are objecting to the SA312 specification though under two theories:
I'm past the point of changing anyone's mind except my own... so can you help set me straight?
ERW and EFW differ significantly in process in my view. ERW heats the weld surfaces first, removes the current, and only then presses the molten surfaces together to achieve fusion. No matter how rapid the process, there's an increased potential in ERW for localized lack of fusion since the heat is not applied while the metal is in contact with the mating part. EFW starts with the metal together, applies an arc to create a pool between the two parts, with the pool being established between the two parts before the arc is removed or moves further down the line... EFW is equivalent to GTAW in my mind. No pressure between the parts is needed in EFW.
Autogenous welds are still welds to me. Section IX defines weld as "localized coalescence of metals ... with or without the use of filler metal." It also defines "weld, autogenous" as "a fusion weld made without filler metal."
And bringing it all together, if EFW pipe is infact welded pipe and subject to part UW, and EFW is unique from ERW... why can't I use EFW pipe in a lethal service?
A) EFW is too similar to ERW. ERW is prohibited in lethal service by UW-2(a).
-And/Or-
B) EFW is not a weld since per SA312 it is done without filler metal. Welding, by definition, requires the addition of filler metal.
RE: SA312 EFW Pipe in Lethal Service
Yes there are rules for supplying these for UW service.
Because of this, long seam weld strength reduction factors (WSRF) were introduced in various Code book Sections for carbon, low alloy, CSEF, stainless steel and nickel-base alloys. So, these welds are indeed now treated as though they are Code fabricated welds with a separate weld strength reduction factor.
By the way, if you look at autogenously welded stainless steel, the weld strength reduction factor is 1.0 and unchanged over the accepted design temperature range. For welds with filler metal there is a weld strength reduction factor.
In the tubing world all filler added specs are for nuclear applications.
My good engineering practice is minimum welds as possible.
r6155
Just so I'm clear, welded pipe is OK for shells & nozzles in lethal service with no additional NDE of the seam on the part of the fabricator?
Mike
I prepare specifications thinking about reducing risks, the cost is not the problem in nuclear/lethal service.
I work only with seamless pipe.
r6155
Welded and cold drawn tube is the way to go. I wouldn't use tube or pipe that was welded to size, the weld variation will be enough to make NDT difficult also.
Yes or No?
Mike
Welded seam at least has a clean bore, most of the time...
EdStainless is right- welded and drawn is beautiful stuff.
As to the code NDT requirements, you've been given good advice already.
