Importing dxf file in NX11
I have imported a dxf file to NX, but it is showing the drawing in the modelling application, not in the drawing application.
Is there a mistake I am doing while importing dxf file?
Pratham,
Using NX 11
Pratham,
Using NX 11
RE: Importing dxf file in NX11
Pratham,
Using NX 11
www.nxjournaling.com
Can you please explain what you mean by stand alone translator?
I'll try and check if it works...
@cowski
True, a few Options are hidden when converting to work part when compared to new part.
I have to contact GTAC itself....
Pratham,
Using NX 11
Here you can specify "settings" through edit settings and translate the DXF and or DWG without even going into NX. You may need to work on setting up an environment variable to set your Java home to a location that contain your Java. See our Example below.
UGII_JAVA_HOME
B:\TC_Java64\jre1.8.0_60
Pratham,
Using NX 11
It worked with drawing view. I tried drawing sheet earlier which had not worked.
Thanks a ton for the help and tip.
Support Team said that they'll look into it(Import wizard)...Will update if I get to know something ..
Thanks again
Pratham,
Using NX 11
Pratham,
Using NX 11
