How to add PMI from part file to master models assembly drawing? NX10/TC10
I made a part with PMI. I need to show some of these informations in assembly drawing, Is it possible and if yes how to do it? (design is in master model concept)
_____________________________
Enjoy your work and have fun!
RE: How to add PMI from part file to master models assembly drawing? NX10/TC10
Yes it is possible, if you use PMI Filters
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
I do not have access to GTAC, so if you can explain it.
And just fyi, I can see PMI in drawing model view (using filter to do that), but I can not place selected PMI it on drawing sheet, and that is what I would like to do.
FOUND IT!
Drafting, select view, right click, Settings, PMI tab, enable PMI and set options what to be visible and in what view!
