steam trap replacement
We are currently replacing to much steam traps in our refinery. I want to know what is the average replacement per year of traps in other plants or industry. This in percentage related to the total number of traps.
Also any information on ultrasound predictive techniques and surveys on traps is welcome.
Steven van Els
SAvanEls@cq-link.sr
RE: steam trap replacement
I don't know about the ultra sound but you can use an infrared temperature sensor to measure the temperature up stream and downstream of the trap. If the temperature is the same, the trap needs repair or replacing.
Don Leffingwell PE
A good rule of thumb that I have found useful is that if the temperature difference across the trap is less than 10 degrees F the trap should be replaced due to excessive leakage.  The ROI on trap replacement easily justifies the initial outlay and the bean counters will love you for it.
Look into GEM Traps.  They're not expensive and are guaranteed to save money.  Just keep them clean.
If the steam trap orifices are small, (less than aboaut 1/8"?) you should consider using a fixed plug-resistant orifice to replace the steam trap. CU Services has had these devices in service for more than 30 years with very few replacement problems. see web site www.cuservices.net
Thank you dgallagher for your link, but I am already in an advanced stage of implementation.
I found a very interesting article "Steam Trap Performance Assessment" of the US Department of Energy
http://www.pnl.gov/fta/15_steamtrap/15_steamtrap.htm
We have already purchased an Ultraprobe 2000 from UE systems, and now we are in the final stage of implementing  scheduling, reporting and analyzing software (inhouse build).
Any comments are welcome.
Steven van Els
SAvanEls@cq-link.sr
Steam traps should not be replaced that often, a good trap should have a life expectancy of three years on high pressure thermodynamic traps, and longer in mechanical type, I represent a company that manufacture steam traps and we also have the only trap testing equipment along with software to maintain a data base of working condition of the traps. Our traps are specified worldwide by companies such as Exxon/mobil and chevron, and is utilized inmost refineries worldwide.
If interested please reply to cmarin@tlv.com or visit our web site www.tlv.com.
Best regards
Carlos
I came across an excellent piece about steam traps on a consultants website, operating out of the Philippines.
Try this URL:
http://energyconcepts.tripod.com/energyconcepts/steam_traps.htm
This site is one of the WEBS best kept secrets..
firetube
Try this URL:
firetube
Educate yourself on the best methods to check your steam traps (I suggest taking an inlet and outlet reading with an inexpensive hand-held infrared- to determine plugging or downstream back-pressure, then ultrasonically listen to the trap to determine status - pass/fail); check your steam traps periodically; input the information into a user friendly software program; begin a steam trap maintenance porgram.  The time to start is now.  Some websites to visit: http://www.steamonline.com
http://www.enerchecksystems.com ;  http://www.conserv-it.com
i want to know about trapping method for isolation and identification compound of plant. I hope you can help me giving the book or disc about that.
wonosari rt01/10 ngaliyan semarang 50186 jawa tengah singapura
Spirax sarco has 2 excellent sources called Hook-ups and steam utilization. About identification, can you explain a little further?
Steven van Els
SAvanEls@cq-link.sr
