Where Can Online Structural Articles be Found? eReader Loving SE's Rejoice
The Specific Need
I would like to round up as many sources of online structural engineering articles as possible. The requirements are:
1) They need to be published online as true online articles, not just linked PDF's.
2) They should be free and not require any login procedure to access.
3) Articles only need to exist, they don't necessarily need to be being published regularly.
Who's got recommendations for me? So far, I've got Structuremag. The articles are available as PDF files but they are also available as online articles (web pages) which is key for my purposes here. I'm seeking more of the same on anything withing the structural domain. Masonry, steel, facade... whatever. Concrete Construction is another example that's working well.
The Background
I read in bed before I fall asleep. I've always wanted to read trade publications but that typically has involved using my iPad which annoys my spouse terribly and has the whole blue light / sleep deprivation problem.
As of this afternoon I now have the Kobo Aura One. You know, because I'm Canadian, I'm a sucker for blue blocked light, and I'm generally a gadget princess. Anyhow, the widget came pre-loaded with an app called Pocket. Pocket lets you save any online article to your Kobo/Kindle etc for offline reading later. With this technology, I finally have what I've been wanting with regard to reading structural articles in bed, with my eReader. I've been demoing it with Structuremag articles and it works like a bloody charm.
The Background
RE: Where Can Online Structural Articles be Found? eReader Loving SE's Rejoice
Journal of Light Construction
Structure Magazine
For precast/prestressed concrete stuff, you cannot beat PCI's achieved journals: Link
Not sure if the above meet your "need to be published online as true online articles, not just linked PDF's" criteria.
- HERON journal - http://heronjournal.nl/index.html
- New Steel Construction - http://www.newsteelconstruction.com/wp/category/tech/
http://www.steelconstruction.info/
http://www.structuraltimbermagazine.co.uk/
https://www.theengineer.co.uk/
http://www.bdonline.co.uk/
http://csengineermag.com/
https://www.aisc.org/modernsteel/
*oops, PDFS:(
Edit: Oops, didn't notice that Ussuri had posted that link previously.
http://www.finehomebuilding.com/magazine
