Adding points from textfile in sketch: journal
Hello guys...
I'm trying to addapt the file2points vb (from sample nxopen) to work inside a sketch.
I changed 2 lines (originals commented out) in below vb but I get an tag not allowed error
CODE --> VB
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Module Test
    Sub Main
        Try
           Dim openFileDialog1 As New OpenFileDialog()
            openFileDialog1.Filter = "txt files (*.txt)|*.txt|All files (*.*)|*.*"
            openFileDialog1.FilterIndex = 1
            openFileDialog1.RestoreDirectory = True
            If openFileDialog1.ShowDialog() = DialogResult.OK Then
                Dim theSession As Session = Session.GetSession()
                Dim sr As StreamReader = new StreamReader(openFileDialog1.FileName)
                Dim line As String
                Try
                    line = sr.ReadLine()
                    While Not line is Nothing
                        Dim pt As Point3d
                        Dim delim As Char () = { ","C }
                        Dim strings As String () = line.Split(delim)
                        pt.x = Double.Parse(strings(0))
                        pt.y = Double.Parse(strings(1))
                        pt.z = Double.Parse(strings(2))
                        Dim p As Point
                        'p = session.Parts.Work.Points.CreatePoint(pt)
                        'p.SetVisibility(SmartObject.VisibilityOption.Visible)
			theSession.ActiveSketch.AddGeometry(p, Sketch.InferConstraintsOption.InferNoConstraints)
			theSession.ActiveSketch.Update()
                    End While
                Finally
                    sr.Close()
                End Try
            End If
        Catch E As Exception
            MessageBox.Show(E.Message)
        End Try
    End Sub
End Module
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
RE: Adding points from textfile in sketch: journal
Try the following:
CODE
Imports System
Imports System.IO
Imports NXOpen
Module Test
    Sub Main
        Try
                Dim line As String
                Try
                        Dim pt As Point3d
                        Dim delim As Char () = { ","c }
                        Dim p As Point
                        p = theSession.Parts.Work.Points.CreatePoint(pt)
                    End While
                Finally
                    sr.Close()
                End Try
            End If
        End Try
    End Sub
End Module
www.nxjournaling.com
Hi Cowski,
Thanks, that worked..
I see I shouldn't have removed the declaration of p
NX9 / TC10.1.2
Yes, that line of code actually creates the point object and the ActiveSketch.AddGeometry method adds the point object to the sketch. One other item of note: if you simply uncomment the line in your code, it will still return an error. This is because that particular line attempts to reference a variable named "session", but the variable referencing the NX Session object was actually declared as "theSession". The compiler will complain that it can't find the "session" variable.
Thanks! Had that the first time indead..luckily I could figure it out myself.. :)
NX9 / TC10.1.2
