ASTM A-105 Acceptable Editions for ASME
Hi all,
I have a questions for ASME Section VIII, Div. 1 materials.
We received a MTR which indicates a flange is made to ASTM A105-14.
Per ASME Section II, acceptable editions for ASTM A105 is 87a through 05.
ASME Section II, Appendix II-200 (c) states that ASTM specs with year dates later than specified in ASME is prohibited, unless a Code Case allows the use.
I looked through the Code Cases, but couldn’t find anything allowing the use of A105-14.
Is anyone aware of any 'catch all' Code Case that would allow the use of this flange on pressure vessels? Or if I'm missing anything, please let me know.
Thank you
Thank you
RE: ASTM A-105 Acceptable Editions for ASME
SA-105 in Section II, Part A states "(Identical with ASTM Specification A 105/A 105M-05)".
Mandatory Appendix II Table II-200-1 shows acceptable Editions are 87a through 05 for A105.
Sometimes, our vendors can only supply flanges that only have ASTM identification. When these flanges are made to the latest ASTM code, we can no longer use them because it's not adopted by ASME.
General Blr. CA,USA
metengr - I'm curious as to your basis for the "unless" phrase in your statement above. Would it be UG-11(c)(3)(b)?
Yes.
