Abaqus parametrized input files question?
I am struggling with understanding how to import parametrized input files. Below you can see an answer from a previous discussion, but I do not understand when “amubashar” says to “replace the parameters with their values.” What are the parameters, and what are their values? I believe the parameters are started with a * such as *NODEPRINT, but I am not certain. Please can someone describe to me what to do? Also, I am acquiring these input files from Abaqus's example input files.
Thank you all very much!
Previous Thread
JayZ900807 (Computer)
27 Feb 09 13:10
Hello.
I am trying to open parametrized input files. I do this by importing them as models. However when i do this, a warning message always comes up:
WARNING: The input file contains one or more data items which have been parameterized. Parameterized input files can not yet be imported into Abaqus/CAE. This occurred while scanning input file for parameterized data. The input file will not be imported.
How can I overcome this problem, and open parametrized input files?!
Thank You
amubashar (Structural)5 Mar 09 07:16
To import a parametrised .inp file in CAE, first open it in any text editor and then replace the parameters with their values. CAE should be able to open the new file.
Aamir
The original discussion can be found at this link.
http://www.eng-tips.com/viewthread.cfm?qid=238787
Previous Thread
27 Feb 09 13:10
Hello.
Thank You
Aamir
