Formulas in Cells?!?!
When I past a formula into another cell and try to edit it, the value of the cell displays the formula!?!?!
Ex.
I have the following formula in a cell..
=IF($BA12=1,VALUE(CONCATENATE($AX12,$AW12)),IF($BA12=11,VALUE(CONCATENATE($AX12,$AW12))," "))
When I edit this formula in any way... the formula itself is diplayed in the cell...not the value.
ANY help would be great.
Ex.
RE: Formulas in Cells?!?!
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
It doesnt seem to be putting the " so I tryed the special paste. Is there any specific type of paste I should try? I tryed selecting formulas and it went into the cell correctly ...but agian, when I try to edit it, it leaves the formula in the cell...
Im editing in the formulas bar (also tried in the cell and the dialog box) then clicking the green check to set it.
The values that the formula needs to display are in 01, 02, 03 format. I needed to change the format of the cell to "text" in order to get the 0 to appear infront of the 1. Otherwise I would just get a 1. Is there another format I should be using for the cell that may help this formula display properly?
Thanks.
Goto Options|Edit tab. It should be the 1st check box on the tab.
TTFN
TTFN
