Has anyone had experience using MecaConsulting's Lifting lug program?
I was wondering if anyone has had experience using the program to design lifting lugs?
Have you found the results reliable?
Thanks in advance.
Thanks in advance.
RE: Has anyone had experience using MecaConsulting's Lifting lug program?
No I have not use the MecaConsulting's Lifting lug program
I do use FE-PIPE FOR THESE CALCULATION by Paluin Research Group.
Leonard@thill.biz
www.thill.biz
I use the MecaConsulting’s programs for a while, and I find results reliable. In case you are not sure with the results you get, go over your input or simply ask MecaConsulting’s staff.
