Dots and Crosses
3
Dots and Crosses
Dots and Crosses
Starting with a grid of dots, 5x5 like this:
Can you draw a cross that encloses 5 dots, and leaves 8 dots outside the cross?
Below is a failed example. There are five dots in the cross, but only 4 outside:
Can you draw the cross that works?
EDIT: THE ORIGINAL INTENT WAS TO CONCEAL THE ANSWER INSIDE A CLOSED "SPOILER" WINDOW.
SINCE THE WINDOW REMAINED OPEN, THE FIRST MEMBERS TO VIEW THIS PUZZLE SAW THE ANSWER RIGHT AWAY. SORRY!
I HAVE DELETED THE ANSWER, AND WILL POST THE ANSWER IN A SEPARATE POST LATER.
STF
RE: Dots and Crosses
Greg, have you found multiple answers? (I take it you saw my accidentally exposed answer before my edit removed it...)
STF
There is no indication that the lines must connect to the dots in the grid...
That was originally in the no-so-hidden spoiler box in the OP.
Spoiler:
The unstated non-requirement is that the drawn cross' vertices are dots. There are a number of crosses that can be drawn that are either non-symmetrical or not orthogonally drawn
TTFN (ta ta for now)
How far can we go being non-symmetrical and non-orthogonal? Could all 4 ends of the cross be different in length and width? Then it will get kinda boring smile
Haha!
You guys are great non-linear thinkers, even when thinking about lines. CheckerHater scores 3 points. 1 for getting the "basic" solution, and 2 for the bonus solution.
GregLocock may have come up with the same or different solutions until he posts them so we'll never know.
I was also trying some non-right-angle corners and passing out of the boundary, but I didn't get far. Now that you and IRStuff have suggested non-orthogonal lines, I got this:
STF
IRstuff,
I think you just added another "non-requirement": lines don't have to be straight.
How many points am I getting for this solution:
http://files.engineering.com/getfile.aspx?folder=9...
Okay! Okay!
My puzzle was way too easy for you guys!
bowright
STF
my solution was a diagonal square cross ... not something drawn by a drunken fly, based on the assumption of using the points as vertices.
RB,
Yes, that was the "original" correct answer, that CheckerHater got on answer 5. Then all these other guys with tesseracts in their brains showed up...
STF
