Working with Technical and Non technical Peoples
Hai
How to get good job in Good Engineering valued company? Difference between Working with Nontechnical peoples and Technical peoples?
REGARDS,
G.SRIRAM.
Dream,Dream,Dream Dream transforms in to thoughts.And thoughts result in action
RE: Working with Technical and Non technical Peoples
2) Technical people are slightly more difficult to insult, but exceptions exist.
Mike Halloran
Pembroke Pines, FL, USA
Thanks for your comments
Am facing Here problem with the production supervisor he is don't know nothing on welding but he is giving acceptance on weldment defects Pin hole is accepted?
REGARDS,
G.SRIRAM.
Do you?
Does the owner give a crap?
Does your government give a crap?
Does your market give a crap? I.e., are you selling welded products where the welds are assumed to be competent and/or regulated in some way?
Mike Halloran
No he is uneducated by experience he is in this position.
Straight way i hold the pipe and said to clear the pipes after view the pipes by an welding engineer. if there is any possibility to do repair or acceptance by standard.
REGARDS,
G.SRIRAM.
