About Piping Welding, Calculations and Codes
Dear colleagues:
I m working in a project where I have to design a water piping system DN 900 using "curved" metal Sheets ( I'm not sure if "curved" is the correct word in English).
I have an issue:
I don't know which is the a code or standard that indicates me the way to calculate and design the longitudinal seam and the seam between two consecutive tubes. Where is the formula/e?. I must do a Calculation Report indicating the formula, allowable stresses, safety coeficients, etc., and the source of the data, etc.
I would appreciate your help.
PD 1: The specifications say I have to use AWWA Codes ( they doesn't help too much...)
PD 2: I have access to ASME Code VIII Div 1 Rules for Construction of Pressure Vessels but one paragraph says that this code doesn't apply for piping...
I have an issue:
RE: About Piping Welding, Calculations and Codes
I have no boss. My work is to do the detailed engineering for different types of subjects, eg metallic structures, In this oportunity I have to face the engineering of the water piping and this topic is very interesting for me as a Engineer.
If you could assist me I would apreciate.
Where are you?
What is your education?
What is your experience?
PN900? That's 36" pipe, what the heck are you building?
What is this project (be very descriptive)?
Sometimes its possible to do all the right things and still get bad results
I'm in Argentina, Mechanical Engineer and more than 10 years as Project Engineer managing Capital Investments Projects.
Now and since 1 year ago I am working in the "other side of the table" doing the detailed engineering and specifications to build metallic structures, air compressed piping up to 6", etc.
As I said, appeared in my desk this new project in which I don't have experience because of that I resorted to the forum for assistance.
The easy way is to hire to an specialist but, I am an Engineer, I want to know how to do...
You can find an attached file that explain the work.
Then, I have the geometry, I have the Pipe, I have the internal Pressure,but I don't quite sure how to stablish the thickness and how to design or verify the longitudinal seam and the seam between two consecutive tubes, and put them in a calculation report.
Was I clear?
Thanks and I look forward to your comments or information
Curtis
To sum it up, I want to solve it because I want to know how to do it regardless of whether the project will be executed or not.
weldstan and curtis2004 gave some tools and now I'm reading AWWA 200,206,207,208 and others related to coating and lining (I can't download Manual M11 de AWWA, If anybody has it ......)
Comment to weldstan: I was reading ASME 31.3-2008 , Chapters 1 to 6 and only find typical details of attachments welds, butt welds, etc. but I can't find, if exist, the way to verify Longitudinal and Circumferential weldings. May be I'm looking for something that there isn't in the code. But must exist a method/code/standard that indicates,with no doubts,the way to calculated/verify the two types the weldings: the allowable strength to be adopt, the theory of rupture used, the Safety coefficients ( yes , B31.3 mentions something in thickness calculation, but nothing for weldings).
I hope I was clear and you can see what I need. If I'm in the wrong way, or there is another way to face the situation, please let me know.
You shouldn’t be asking the questions you have asked, the way you have asked them, while pretending to be a qualified engineer for this project. Wherever you are, you are still dealing with the public health, safety and welfare, and if you aren’t qualified, by past experience, you shouldn’t be doing this kind of engineering without supervision by someone who is qualified. We all have to do any given engineering problem for the first time, intending to learn from that effort, so your willingness to learn is good (“this topic is very interesting for me as a Engineer”),
but we should be doing this under the supervision of an experienced engineer who can give us guidance. We should not be messing around with other’s safety and health while we learn a new subject. You have to know what you are doing to be a responsible engineer, not just have a bunch of formulas from a code, or some computer program. It seems to me that you should be buying some appropriate pipe for your project, and then making girth welds between lengths of pipe, both controlled by your design and building code for this piping system, not actually manufacturing the pipe from rolled (“curved”) steel plate (“Sheets”) as you seem to indicate.
It seems to me that what you wrote talks more of you that of me. You don't know me.
If you can't add something positive, please don't give me lessons about SHE.
Meanwhile the subject remains what I asked to the forum.
This probably doesn't instil confidence in forum readers who are wondering where is your guidance for this project.
Have all the other engineers been laid-off and now management is doing the technical work? Are engineers required to stamp drawings where you are?
I don't have formal guidance for this subject and because of that I resorted to the forum.
I'm not sure if I am doing the correct questions. As you can see in previous posts I have data input, and the data output is a calculation report. In the middle, the way, I have to respect codes/standards and explain why I propose what I propose.
After several posts is probable that the core of the subject I want to solve has been lost. Basically is the "Comment to weldstan" in a previous post.
If you have a question that clarify what I try to say, please let me know.
You're new on this site so a few tips,
The site is called Eng tips, not Eng-free consultancy.
Reacting to advice given in a negative way generally does not elicit further responses
To get the best you need to provide some background and data. Note I tried to download your file and it wouldn't. Much better to use .pdf or .jpg rather than .dwg
I'm still confused as to what you're trying to do here.
You appear to be trying to make seamed pipe from rolled plate. Why?? All the piping and pipeline codes I deal with assume you buy ready made pipe to acceptable materials and pipe specifications which they list in their design codes.
I'm not familiar with the AWWA codes, but B 31.3 and B 31.4 especially provides you with allowable hoop stress calculations for given diameters, pressures and yield strength of different materials.
The codes indicate certain key welding information, codes and parameters to use.
I've been doing this type of work for over 30 years and never had to "design and calculate" the seam or girth weld. I just buy pipe to a certain specification and specify a welding code to use and that's it.
I think there seems to be a lack of experience all round if you're being asked for this data.
You say you're being asked to design the system, but the questions imply you're designing the base pipe itself??
A Project Engineer will never be a good technical engineer - that's why they opt for the project engineering route!!!
MJCronin
Sr. Process Engineer
I agree with you but when you have to change to the rhythm of the needs and the new scenarios in the professional career, you must adapt (excuse me my written English).
Following the piece of advice "More details = better answers":
I have attached the file in PDF version (dimensions in mm). I hope it explain your question about "designing the base pipe itself" in your last paragraph.
Hypothesis: Currently I'm reading the B31.3-2008. The scope mentions that apply por water piping.
It seems to me that B31.4 applies for hidrocarbures, liquid anhydrous ammonia and related but not for water ( please see the Scope).
With regards to the pipe, due to the diameter aprox. 900 mm (NPS 36") and according with purchaser's specifications we have the option to made the pipes from curved steel plates. B31.1 considers this situation using a Basic Quality Factors for Longitudinal Weld Joints in Pipes,
Tubes, and Fittings,(Ej). The Basic allowable stress "S" and "Ej" are used to calculate the thickness "t", accoprding to B31.3. In this case I have to perform a Calculation Report.
But, here is where I not sure what is the code or method to apply, if the pipe is made from welded curved steel plates as mentioned above, to verify the Longitudinal Seam.
Or just, with "t'" I adopt a Commercial pipe thickness "T" and I verify the Longitudinal Seam using the known formula for full-penetration welded butt joints, as usual?
If you need additional details, please let me know.
I think what you're asking for is what is the joint factor applicable for longitudinal welded pipe?
Depends on which design code you're using. B 31.3 didn't like longitudinal pipe so applied a 0.8 factor on the wall thickness
If it's AWWA then I don't have much experience of that - It looks to me like you need a copy of AWWA Manual M11 https://www.awwa.org/store/productdetail.aspx?prod...
Apply the code that the client has told you to.
Comment for LittleInch: I have attached the file in PDF version with new name DATA.
Maybe I didn't explain very well. What I looking for if is there a Code or Standard that indicates how to verify the Longitudinal Seam to form a tube from curved steel plates.
In other words: must be exist a method/code/standard that indicates,with no doubts, the way to calculate/verify this type of weldings: the allowable stress to be adopt, the theory of rupture used, the Safety or reduction coefficients, etc., with a given plate material and a given internal pressure ( B31.3 make mention of how to calculate the pipe thickness, but there is no information or guidance about Longitudinal weldings).
AWWA: with regards to AWWA, the specific AWWA 206-97 FIELD WELDING OF STEEL WATER PIPE says:"...The design of field-welded joints is not covered...."
PD: Someone has a copy of M11 Steel Pipe -- A Guide for Design and Installation, Fourth Edition (PDF)?
I am knod of fascinated with this post as it is one of the strange rones to appear.
Your drawing, which finally downloaded, appears to show a curved pipe ( not sure if this is horizontal or vertical, but never mind) made up of multiple short lengths of pipe, presumably your 1.5 m lengths of 900mm ND welded at what I can only assume is some sort of mitre bend??
Now how and why you have arrived at this design is beyond me and maybe you can fill us in on this.
The multiple welds, both axially and girth welds would seem to make this very expensive and if you are actually trying to make this pipe, it strikes me more like someone trying to build a car based on buying all the spare parts. Some one once calculated that to do it this way made a $15,000 car cost $150,000....
In answer to you question I have attached a brochure from a steel mill which explains the process. It also has a list of pipe specifications in the back including AWWA C200 which I think is your best point of call.
Normally seam welded pipes ( there are multiple ways you can weld the seam) are examined by UT and sometimes X ray depending on the specification and the purchasers (i.e. you) specification.
Allowable stress and safety factors are determined by the code you are working to, hence you need to obtain (purchase) a copy of the code. They vary from 0.72 to 0.5 generally over SMYS (min yield stress).
Theory of rupture I don't understand, but Barlows hoop stress formula is used in all pipeline codes I've ever seen.
So can you come clean here and advise what the design conditions are:
Fluid - water?
Design pressure?
Material of this curved plate
Wall thickness you intend to use
Type of seam weld you intend to use
Why you're not buying ready made pipe from a supplier and then bend it?
what this mysterious curved pipe is all about
Good luck
The subject about large diameter piping system has resulted very interesting to me and I think I will continue researching about it. Thanks.
Despite of I will look for external assistance I will answer the questions of the last paragraph.
Fluid: water
Design pressure: 10 BAR
Material of this curved plate: A53
Wall thickness you intend to use: 1/4"
Type of seam weld you intend to use, full penetration according to AWWA 200 or B31.1
Why you're not buying ready made pipe from a supplier and then bend it? We assume that a 900 mm ND pipe and thickness wall of 6.4 mm can't be bended as the curve showing in the drawing without dangrous deformations or due to the buyed pipe lenght of abot 12 meters or more the "bending" process will be too expensive.
what this mysterious curved pipe is all about: is a part of a larger piping network. The curve is to cross a little river.
That's a pretty thin pipe (D/t of 141??). I'm not sure how you were planning on getting the pipe below? the river, but I would have used some formed bends of a thicker material to get the angles and the y just used some straight bits of pipe.
You might also have significant forces on the pipe from soil and other loads.
One thing I forgot - Keeping the pipe within some very strict ovality limits as you make it will be very very difficult. At that thickness of material, any ovality will mean your pipe edges won't match up to weld them and any force to clamp them together would just buckle the pipe.
Taking advantage of the natural catenary curve that the pipeline assumes under its own weight, you could save some welding by using longer sections.
Will you also manufacture the straight and curved pipes that will connect with this bridge?
Please, follow this link:
https://www.linkedin.com/in/paulyassa
"Engineering is achieving function while avoiding failure." - Henry Petroski
Irrespective of the wisdom of trying to learn on such a job how to manufacture, coat and line, and handle seemingly from scratch all other nuances of large diameter steel piping supply on such a job, unless this piping is required to closely follow the contours of a bridge (neither pictured nor noted) horizontally curved for some unknown reason, this appears to be a quite inefficient in material and labor, and perhaps also risky way to run a large pipeline across a river. This inquiry at the very least begs for some more information to be supplied
The drawing I've attached with short mitered 60-inch (1500 mm) pipe segments is a preliminar idea or design that the client proposed. The way to form the curve layout can be changed according to the availability of material, materials costs, labour costs, new desig, manufacturing labour, assembly methods on site, e.g. using some formed bends of a thicker material to get the angles and some straight bits of pipe, as LittleInch mentioned. But I don't know, as I said is not defined. I didn't see this issue yet. But the curved layout must be
respected.
The curved pipe layout is aerial, crossing the river and supported by an metallic structure (like a bridge) with an aerial walkway for maintenance (out of the scope) .
The pipe thickness was not calculated yet, can be thicker.
The straight and curved pipes that will connect with this bridge are out of the scope.
If you have a recomendation how to form the curve layout ina efficient way (labour, material, etc.) will be appreciated.
Lnewqban: The link is not available, could you attach it in a post?
[Edit: although this may be because I am logged in to LinkedIn, so no guarantees. The image at that page looks like what the OP seems to be talking about]
This pipe is way too thin for a self supported or supported structure like what I gather is being proposed.
The pipe wall thickness for the crossing needs to be a lot thicker to withstand all the other loads a buried pipe doesn't see and to be practical to construct.
"Cold" bends of 40D are the most common available, but in terms of induction bends you can probably get any radius you want.
Pipe bridges tend to be built as 90 degree (sometimes 45~) 3 or 5D radius bends, a vertical riser, another 90 or 45 then a flat section across your river, road etc) then the repat on the far side.
Arch type pipe bridges would tend to be much smaller diameter, short distance 40d curve pipes.
Some do look like this but note the flanges and the large concrete blocks at each end...
But most look like this
As to efficiency in material and labor at least horizontally curved bridges are in general some anathema to this, as explained at https://policymanual.mdot.maryland.gov/mediawiki/i... and I suspect many other places. As to signficantly curved/mitered welded or flanged pipe layouts in general, such are also special and more expensive and labor intensive in general than layouts with straight pipes, unless the curves can be traversed e.g. with deep-socketed rubber-gasketed pipes, that can even eliminate bend fittings that are much more expensive and some more labor-intensive than straight pipes.
I hope this information helps.
The welds in pipe are part of the material, not fabrication welds. There are two separate questions, what is the design code involved, and what material specification must the pipe meet.
I have edited my previous post, Gabriel.
When you ask about "how to form the curve layout", are you referring to the arc of the bridge or to the rolling of the segments of pipe?
If acceptable to the client, I would use the same straight pipes which with your bridge will connect at both ends, manufacturing only several of a flanged "connector" rolled pipe to connect two consecutive straight sections, creating the appropriate angle between those.
An alternative would be cutting both ends of those commercially available straight pipes.
That would save around 50 meters of longitudinal welding, with all the possible deformation and potential points of leak or corrosion introduced by manual welding.
That option would gain the rigidity and straightness of standard commercial pipe, even if you have to reduce the length of straight sections in order to achieve a smoother arc.
Consider the limitations of your manufacturing process and rolling machine regarding maximum length and thickness of the steel plate, as well as how close to the edges the rolling will happen.
You may need to eliminate the straight left over at both ends prior to welding via oxy-fuel cutting.
Shorter/lighter sections may make cutting the contour of the miter joint easier in a shop.
Too bab you're right, that most pipe bridges look like the last pic.
for the OP, if you're trying to calc the longitudinal seam of the pipes, note that most codes don't require calculating full-pen welds (at least when the basic requirements of construction and welding are fulfilled).
The weld is typically stronger than the base material(s).
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
Was it cable stayed to resist wind loads or just thick pipe at the base??
What was the mitre angle?
