Web Crippling on Elevated Composite steel deck
I am proposing to support a rather large (Pu=6k) load on an elevated composite deck system.
The load will be applied through a 4"x4" sq. plate.
There will be post shoring installed beneath the applied loads
The allowable phi*Rb for this deck (4" bearing) is 1220 lb/ft.
My question is, should web crippling be a concern?
Thanks in advance for any advice.
RE: Web Crippling on Elevated Composite steel deck
If your load is right over your shoring then I don't think that crippling is a concern. I'd investigate the concrete's ability to transfer load through the floor deck in its own.
Thanks for the reply. We would anticipate (design) the shoring to be directly below the applied loads.
