Wood GWB or WSP Shear Walls
Is there any guidance somewhere for shear capacities of Wood GWB or WSP shear walls with resilient channels?
"It is imperative Cunth doesn't get his hands on those codes."
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Wood GWB or WSP Shear Walls
Give and take is a good thing, particularly because we are not getting enough detail in arch progress drawings earlier in the process. Lesson learned to ask ahead of time.
Unfortunately, sandwiching the channels between GWB and WSP directly attached to the studs also neutered the acoustical performance of the resilient channels. As such, it's tough to have one face of the wall be both the shear panel and the RC acoustical barrier simultaneously. Architects often don't pick up on that.
I reached out to Woodworks, but heard nothing yet. I suspect they will say the same as Triangled et al.
Dik
