Bentley ProjectWise Explorer
This question is for anyone who has experience working in Bentley ProjectWise Explorer.
https://www.bentley.com/en/products/brands/projectwise
For instance, when you open a PennDOT BAR7 ("Bridge Analysis and Rating", *.dat) file via ProjectWise, it downloads the file to your local computer.
You edit the file, run the analysis, and generate the output file (*.out) on your local computer.
Then ProjectWise automatically updates the server copy of the *.dat file, but doesn't recognize the newly created/updated *.out file.
This is the case for a lot of non-bentley-integrated programs. Has anyone out there found a good way (scripting or otherwise) to automate the process of updating "secondary" files on ProjectWise?
(not just manually dragging and dropping the updated files yourself)
RE: Bentley ProjectWise Explorer
