ABAQUS MACRO - SUFRACE PROBLEM
I made a macro file of a part. The idea of macro is to change the amount of cuts (see the attachments). When i change the amount of cuts, it also changes the amount of faces. Because there are more faces the macro selects the wrong surface. I am wondering if there is possilble somehow to lock those surfaces, or define them somehow so that they always stay in the same place.
attachments: http://files.engineering.com/getfile.aspx?folder=1...
http://files.engineering.com/getfile.aspx?folder=9...
http://files.engineering.com/getfile.aspx?folder=6...
http://files.engineering.com/getfile.aspx?folder=c...
http://files.engineering.com/getfile.aspx?folder=4...
RE: ABAQUS MACRO - SUFRACE PROBLEM
See Scripting Reference Guide 7.6 FaceArray object
