Mechanical Well in a Hip Roof
RE: Mechanical Well in a Hip Roof
I might be tempted to add 10% or so to the leeward roof pressure but I don't think there'd be much added to the lateral force of the building.
Can you treat the two sides as separate monoslope trusses, then see what happens when you put them back to back? I assume that JAE estimate of 10% increase is probably close.
