What's the proper way to call out a tabulation block?
We need to make a bunch of parts and they're all exactly the same except for one hole. About 50 have a .060" hole and the other 50 have a .039" hole. What's the best way to call out 2 different dimensions for the "same" part/feature? Tabulation blocks?
Do you dimension the hole with "A" and then just have 2 different dimensions in a table? Or is there a different way to call it out?
RE: What's the proper way to call out a tabulation block?
I don't know what a 'tabulation block' is. Do you mean a hole table?
In either case, it sounds to me like these parts should have separate part numbers. Which means separate drawings.
Your tabulation block should have at least two columns, Part Number and DIM "A".
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
What the other two said. Two column table with two part numbers and dimensions for dimension A on your drawing or two separate drawings that only differ by one dimension. Either way it's definitely two part numbers if you go by the fit, form, or function rule.
I once saw a hole chart on a drawing that was actually titled "TABULATION TABLE". smile
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
echelontf,
I'll echo previous responses and say that a tabular tabulation table is likely the best approach.
Another approach I've seen used, particularly in cases where only a single dimension is variable, is to directly use the numerical value of the dimension (in appropriate units such as thousandths of inches) as the part number suffix (dash number). A drawing note would explain the scheme.
Quote (example drawing note)
Part number: 12345-XXX where XXX is the numerical value of dimension A in thousandths of an inch.
I'm not sure what, if anything, ASME has to say about this method. If anyone happens to know, I'd be interested to hear.
pylfrm
Do you have 50 different shape drawings each with a hole size option? Then use a '-' numbered part scheme, -1 for the .060 hole and -2 for the .039 hole on each of the 50 drawings.
If more of the shape can be tabulated, you can reduce the number of drawings.
Ben Loosli
