Min rad detection
Min rad detection
Min rad detection
Is there any way we can identify the min rad in our model & also can we shade all the rad as per their value
Girish
RE: Min rad detection
If you are using NX9.0.3 or above, you could try using Visual Reporting to do what you're after.
There is a report called 'Face Minimum Radius' which does what you're after.
https://vimeo.com/158119612 is a video I did a while back which shows how visual reporting works (not sure if it showed that report, but you should be able to figure out how to find it).
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
There's a ridiculous assortment of functions for doing this. They're in the Analysis--Shape submenu. The functions to try are Radius, or Concave Faces, or Face Curvature.
If you can live with a little manual selection of faces to inspect, use the "minimum radius" feature.
The purpose of the function is probably identify the largest possible tool that can cut a surface. - It will on solid bodies only report concave radiuses.
If you select a convex only solid body, you will not get a result.
Tomas
Thanks guys,
I got what I am looking for,
Visual reproting looks cool.
G
