Edit Routing Path/Objects
I'm working on a hose routing project and since we're early in the design, the endpoints of the hoses and tubes are changing locations frequently. I've been using the Mechanical Routing application by setting up my datum points, creating a linear path through the points, and then assigning corners. But this is the first time I've used the Routing app and I can't figure out how to edit the path once I've created it. I would like to be able to make the routing control points associative to the datum points so I can just move the datum points to the new locations and the routing path moves with them, but if that's not possible, is there a way to edit an existing routing path/control point without deleting the old one and starting over?
EDIT: Is it also possible to edit the radius of a corner once it's been assigned?
RE: Edit Routing Path/Objects
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
