HELP NEEDED URGENT ...HELP US SOLVE A ISSUE REGARDING ELECTRO MECHANICAL DOOR LATCH
DEAR SIRS
WE HAVE A VENDING MACHINE THAT WE NEED TO PUT A ELECTRO MECHANICAL LATCH ON BUT WE NEED IT TO BE ULTRA DISCRETE SO NOT REALLY IN VIEW.CAN ANYONE RECOMMEND A PRODUCT THAT CAN OPEN AND LOCK THE DOOR ON DEMAND FROM OUR PC .ANY HELP IS APPRECIATED .
RE: HELP NEEDED URGENT ...HELP US SOLVE A ISSUE REGARDING ELECTRO MECHANICAL DOOR LATCH
TTFN (ta ta for now)
Here's one for industrial enclosures. They take a 120 or 230V pulse, so whether or not you have that and how you would control that via a PC is a separate issue. But chances are, someone makes a version of something like this with a built-in low energy control signal interface. Just don't expect to find one that can be POWERED by a PC output. Large solenoid circuits are not something you want to power via sensitive electronics.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
You can also talk to a PLC via a PC which I've done before but it's quite complicated for the sake of opening a latch.
