Locating Hex-shaped Pin Holes
Plastic part. I have a pattern of 4 hex holes for round pins to go into. How do I locate the hex hole pattern? My first thought is to treat it kind of like a round hole pattern, but show dimension across the flat of one hole as follows:
4X .072 HEX
|LOC|DIA .005M|A|BM|
Upon doing some research, I seem to find the solution to be using profile of the hex shape, but I'm not sure how that helps to locate the hex.
Any and all help and/or examples is appreciated.
4X .072 HEX
|LOC|DIA .005M|A|BM|
RE: Locating Hex-shaped Pin Holes
You consider cylindrical envelopes created inside of hex holes and locate those envelopes as if they were cylindrical holes.
Functionally you place cylindrical pins into the holes anyway, so the (imaginary) checking fixture will have set of round pins to check hex holes as well, which is exactly what the idea of irregular FOS is.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Are these accurate holes on a substantially less accurate pattern?
JHG
The top FCF controls the size, location, orientation and form.
http://www.dimcax.com/gdt_web/september-00.htm
-Dalai Lama XIV
Season
we do this all the time.
unless you need to control the hex holes orientation - that's a whole new ball game.
but you said round pins fit into them, so gauge it with round pins!
Suggest You detail the hex-hole planform and edges carefully: these aspects may be structurally important.
Are internal hex corners rounded-off [radiused] to eliminate stress concentration of a sharp-entry corners that might initiate cracking under pin-interference-pressure?
Are entry and exit edges chamfered or rounded-off [radiused] to facilitate pin entry and eliminate sharp edges that might initiate cracking or chipping... especially at the hex corners?
These details could be added to a basic 'sharp-hex' profile as 'typical' details.
NOTE.
Stress guys hate 'random orientations of sharp entry features' [corners]: suggest the hexes have a common hex-orientation in either an [X-Y] or [polar] arrangement.
Regards, Wil Taylor
o Trust - But Verify!
