How can i change NPT Thread angle from 3º to 1.783º on NX.
i am trying to draw 1/4 - 18 NPT thread. But when i measure NPT angle , i saw it 3º. It must be 1.783º (1º47'). How can i change this degree?
Thanks in advance.
RE: How can i change NPT Thread angle from 3º to 1.783º on NX.
In your ugii_env.dat (name can vary based on your setup, but file, set the following variable:
# Set angle of pipe thread taper
UGII_NOMINAL_DRAWING_THREAD_TAPER_ANGLE=1.7833
-Dave
NX 9, Teamcenter 10
Dave,
Thanks for your help. I am looking for I found "ugii_env.dat" file in UGII folder and opened it with notepad. But did not find.
UGII_NOMINAL_DRAWING_THREAD_TAPER_ANGLE , in this file.
1. I will add this "UGII_NOMINAL_DRAWING_THREAD_TAPER_ANGLE=1.7833" in this file or i will find this row and change older?
2. i tried this and can't save , an error appeared "access denied".
Have any suggestions about this matter?
Thx
Ok i solved.
Thank you Dave.
Take Care.
