Starting a hydraulic engineering consulting firm
Hi everybody,
I'm going to start a hydraulic consulting engineering firm in a month by myself. I would like to start design for architecture consulting firm and when I will grow sufficiently carry hydraulic works (water distribution, sewage network...).
I learned a lot about the subject but one of my unsovable problems is this one:
Since I obtained my degree ( 2 years ago) I only worked in operation and maintenance. Even if I learned design through books and courses I don't have any experience in this field.
How can I convince potential clients that I can do the job ?
Should I decrease my fees to get clients ?
My personnal situation don't allow me to work as an employee. If I could I would work for a consulting firm to get some experience.
Thank you in advance for your advices !
RE: Starting a hydraulic engineering consulting firm
In my opinion, you should not be starting an engineering firm without appropriate experience and knowledge of the principles and practices of the engineering discipline in which you want to practice.
To answer your question about how to convince someone you can do the job....considering your subject knowledge and experience deficiencies, I see no way to do so honestly and ethically.
The aforementioned countries, you would be violating the law by practicing engineering without a license. And, you don't even have enough experience to get a license in some jurisdictions; typically, in the US, you would need to have worked under the supervision of a licensed engineer for a sufficient time before you could even sit for the PE license exam.
I don't understand your comments about being an employee; how is working for a consulting firm not being an employee?
TTFN (ta ta for now)
I will first precise my situation and then explain my plan for the next months.
After my graduate degree in Hydraulic Engineering obtained (5 years after High School in Algeria and the PE process doesn't exist), I worked for one year as an Operation Engineer in a Waste Water Treatment Plant and then one year as an Design Enginner for a firm making containerized WWTP for camps in the Sahara.
I had to quit my job to replace my father in the familial entreprise (A little Holyday village). That is why I cannot follow the 8-5 work schedule and then be employed in a consulting firm.
8 month have passed sinced I quit the field of engineering and I'm searching away to come back to it without letting my familial responsabilities.
All of you think it will be difficult to convince clients and do a good job without a practical experience.
What type of work do you think is appropriate with my experience ?
As before thank you for your ideas.
Please don't do that. Now, the market is quite aggressive these days. We are all professionals and doing that you will hurt the market wherever you are located. Ron gave good advise, get experience, create your business and keep the professionalism in your area. You (and us) will make money that way...
There are far easier and less painful ways to go broke.
Reaction to change doesn't stop it
Thank you for all your responses.
