Hi, quite recently I saw a plunger
Hi, quite recently I saw a plunger type positive displacement pump which had a strange plug at the bottom of the casing. The plig seemed to be slighlty leaking while running. When I removed the plug l, I found that it is not a plug but a sintered bronze air filter. This air filter was on the hydraulic oil side of the casing.
My question is that since we do not have a spare air filter, can I plug this with a temporary plug (not filter) and run the pump Also what is the purpose of this air filter, at the bottom of the pump casing. Thanks
RE: Hi, quite recently I saw a plunger
Johnny Pellin
