FEMAP: Process outputs using API
Hello, I am trying to do a simple procedure using Nastran outputs in FEMAP. I have 2 sets of results for 1 model. I would like to create a new output set that contains the ratio of output 1 divided by output 2 for all elements in the model. I was trying to code a femap API to do this, but did not get very far. Can anyone help with this? Thank you.
RE: FEMAP: Process outputs using API
Sorry, for the mistake. Im a newcomer.
