EGDT
EGDT
Who knows anything about EGDT... anything at all?! how to open (or what programs) open it would be greatly appreciated!
RE: EGDT
Or are you asking about a file format?
TTFN (ta ta for now)
RE: EGDT
Early Goal Directed Therapy?
JHG
RE: EGDT
in the Cad model, you can open a part and inside, the GD&T is programmed into the model.
I see it sometimes using PMI, but apparently there is something more advanced where I can highlight a surface and read its GD&T callouts directly...
RE: EGDT
This is all software dependent, however, and you'll get better info in the forum for your specific software. There are Solidworks, CATIA, CREO and UG/NX sections, here, for example. Among others.
There is a semi-immature ASME which hasn't been very widely adopted (IME, seems many companies are still rolling their own ideas of 'standard' when it comes to MBD/PMI) regarding this topic; ASME Y14.41
RE: EGDT
however, today my world was turned upside down when I was informed a customer was able to open an egdt drawing with spinfire...
usually you get screen dumps of the egdt (we don't use NX) but its hard to see which surfaces they intend to call out...
RE: EGDT
In SolidWorks, you can directly apply GD&T to the model. In SolidWorks 2017, this is called MBD. If anything other than the designer applies it, it is probably wrong.
JHG
RE: EGDT
I think they are confused and seeing PMI & calling it EDGT, its got everybody's feathers ruffled
"how come you haven't seen the EGDT?!?!? YOU NEED THE EGDT!!"
RE: EGDT
While Y14.41 is slow to be adopted across the board, the limitations seem to have been both software capabilities and company culture. The software capabilities have improved dramatically, but there is still the issue of a company aligning all of it's different groups and vendors to get on board with the new methodology.
For the most part, we use 3D jt or pdf files to communicate with those who don't have access to the NX files directly.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
RE: EGDT
RE: EGDT
-Dalai Lama XIV
RE: EGDT
I was at a presentation on SolidWorks 2017. They asked if any of us were using MBD. I replied "Yes, and I hate it with a passion!" Then it turned out it was a module within their software, and not just a procedure.
JHG
