wave geometry linker in NX9
Hi all,
can any one please provide the procedure for creating the wave geometry linker.
i have done assembly for some parts, i need to do some machining operations on that assembly. how can i do this??
i tried using wave geometry linker, seperate linked bodies are creating for each part. I need to do the machining on the assembly.
can you guys please give a suggestion on this.
Battu
RE: wave geometry linker in NX9
Hi @battus,
I have a short article, it is about fix at the current timestamp feature, but might be useful for you - the article.
www.CADabout.ru
