wave geometry linker in NX9
Hi all,
can any one please provide the procedure for creating the wave geometry linker.
i have done assembly for some parts, i need to do some machining operations on that assembly. how can i do this??
i tried using wave geometry linker, seperate linked bodies are creating for each part. I need to do the machining on the assembly.
can you guys please give a suggestion on this.
Battu
Battu
RE: wave geometry linker in NX9
You should have better succes with your question on the forums below...
http://www.eng-tips.com/threadminder.cfm?pid=561
https://community.plm.automation.siemens.com/t5/NX...
If with machining you mean CAM then ask on the manufactering forum...
https://community.plm.automation.siemens.com/t5/Di...
