Modeling Gears in NX8.5 (No Toolkit)
Other than the CG Toolkit (China license only), does anyone have a good method for modeling gears in NX? I'm trying to create a set of bevel gears and can't find a good way to do this. I've tried using a GRIP function but that only gives the tooth profile, not an actual solid. This would also require me to make a new part every time a design parameter changed (diameter, thickness, number of teeth, etc.) Is there another GRIP out there or something that creates a solid gear based off user inputs and can easily be edited afterwards?
Attached is an image of the resulting attempt using the current GRIP.
RE: Modeling Gears in NX8.5 (No Toolkit)
It does create a solid body.
Why do you think you have to make a new part every time a s design parameter changes? The program will create a new body, but you just substitute this body into your model in place of the old one.
I guess I should clarify; the GRIP wouldn't require me to make a new part every time a parameter changes, rather to delete the current surface and start over inputting all the parameters, as opposed to just changing one. This isn't a huge concern, and I would be okay with it if it generated actual solids. I've only seen examples that create solids for regular spur gears, not bevel gears.
Can you post the UDF part
Thanks in advanced
I'm very thank you.
