Lateral Earth Pressures from a rock cut slope on a retaining wall
Hi Everyone,
I have a unique situation where I am building a house by cutting into a hillside for my building pad. The backside will be a near vertical cut in rock and there are two retaining walls that will be almost stacked on top of each other. See image.
How do I determine the lateral earth pressures including seismic in this scenario?
RE: Lateral Earth Pressures from a rock cut slope on a retaining wall
There's a paper in the 1987 ASCE Journal of Geotechnical Engineering "Earth Pressure on Retaining Walls Near Rock Faces" by Frydman, which explains how to calculate Ka. I can't post the paper because it's copright material. Try this link, that was posted here a few years ago:
Link
Thank you so much for your very prompt response bridgebuster. I have already purchased that paper and have reviewed it. What about for seismic conditions on restrained walls?
Any idea there?
If a vertical cut can be done, there must be no adverse defects/beddings etc, Earth pressure should be zero. Earth pressure theory ka or kp does not apply for rocks, except very weak rock like soils.
Hi Henryzau,
Thank you very much for your response. What about the little amount of granular backfill required behind the wall for drainage purposes?
