Insert Settings.
Insert Settings.
When I use the insert block option for the first time after opening the drawing, the select position box is unchecked, and the block goes off, I know not where.
Is it possible to set up so that that box is always checked.
As ever, thank you for your help.
BC
BC
RE: Insert Settings.
