Export Isoline coordinates from SEEP/W to Excel
Hi guys,
i'm a student and i need your help. I’m using SEEP/W with Geostudio 2012. In the attached image you can see a zero pore-water pressure isoline. I would like to export its coordinates to excel. I tried to build a graph from Draw>Graph option but I can not find a way to display the coordinates. Is there a way to do what I want?
Thank you
Thank you
RE: Export Isoline coordinates from SEEP/W to Excel
