Down guy anchor holding power - PLS-CADD/ PLS-POLE
Hi all,
Wondering if anyone delved into picking specific anchor type & holding power in PLS-CADD/ PLS-POLE. I'm working on one of the OH distribution projects where I may need to use different holding power anchors (varying from 10,000 lbs to 19,000 lbs) based on the primary & neutral strung on the pole.
I don't see any way to make an anchor selection in PLS-POLE - any input is highly appreciated.
RE: Down guy anchor holding power - PLS-CADD/ PLS-POLE
I haven't used it at all but there is a Connections And Anchors (CAN) item in the menu where I think you can specify data on connections. Read the manual on this feature or call or eMail the PLS boys and they will be happy to explain it to you. I don't have my PLS key at home or I would check it out.
Good Luck
_____________________________________
I have been called "A storehouse of worthless information" many times.
