Section view NX11
Section view NX11
Section view NX11
Hi friends
We have a problem with section view using NX11 Drafting, when I create a new view and I need to get another view for this one, both views move.
I need to "break" the link for those views.
someone of you have any idea?
Thanks in advance
Tom
NX10 soon NX11
RE: Section view NX11
When you place the view,in the view menu, switch of associativity.
This will make it move independent from parent view.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
NutAce
Thanks for your comments, we find this:
>select view >RMB >view alignment > suppress hinge method >cancel
regards
Tom
NX10 soon NX11
Tom,
Can you clarify on the exact course of events in this ?
The option "Switch off..." which Ronald mentions is not the hinge line, i think, but "Associative alignment". ( it appears as soon as you have placed the section line but before placing the view.)
- If someone asks me about this associative alignment between views it's a pretty useless & annoying feature implemented only because some other systems has it and then NX must have it too....
But, that's how the market works.
You can turn it off in the customer defaults:
Drafting general / Setup - Standard "customize standard" - Drafting standard - View- Workflow - General - Associative alignment
Tomas
Ok. I guess we are done . smile
Tomas
