A182-F91 Chemical composition
Hi, I have question for the chemical composition on the material certificate. (Material: A182-F91)
ASTM A182 standard, Table2 shows the chemical composition.
In case of F91 grade, we can see Zr 0.01 "D"
"D": Applies to both heat and product analyses.
If product analysis for the "Zr" is not indicated in material certificate, is it rejectable?
Thank you in advence.
RE: A182-F91 Chemical composition
What exactly do you have in terms of information related to the Grade 91 material? I have seen material certificates mean compliance with SA-182 with basic information. Do you have the detailed material or mill test report that provides a complete chemical analysis of the forging?
