Chiller Structural Foundation
Hi, everyone.
I'm looking into the requirements that I should make to the structural engineer for the installation of a magnetic chiller in a roof.
After looking into thread507-299291: Equipment pad/foundation question? I'm understanding that if he provides a 6'' maintenance slab and I specify that the equipment is provided with vibration isolators a floating isolation slab isn't required. That would save him a lot of headaches due to the reduced weight. Could someone guide me to a resource for specifying chiller foundation?
Regards.
EloyRD
Regards.
EloyRD
RE: Chiller Structural Foundation
The rest is up to the structural engineer. He is responsible to build the structure to survive the residual vibration from your equipment.
Mike McCann, PE, SE (WA)
Thanks for the input.
I've been having a really difficult time getting information from my local dealers of Arctic, Smartd, and Daikin Chillers. They do not seem to be able to obtain a data sheet with vibration data from their headquarters, and my vibration isolation provider requires that information to propose a solution that leaves residual vibration that the structural engineer can evaluate against the post-tensioned slab roof.
This is becoming a pain in the ass. Had you had to deal with a similar issue?
@msquared48
Thanks. The structural engineer is having a hard time designing over a post-tensioned slab without a vibration check. Hope we get some information soon.
