Y14.5 Dimensioning Question
Is it okay to have datum and ordinate dimensioning done on the same drawing per Y14.5?
RE: Y14.5 Dimensioning Question
If I understand what you mean by 'datum dimensioning' I don't generally like mixing them but if properly applied then yes it's OK and there are cases where you might want mostly ordinates and then a few direct dimensions to reflect functional requirements.
I assume you are setting your 0 ordinate origins to correspond with your datums.
Questions like this may be better in forum1103: Drafting Standards, GD&T & Tolerance Analysis
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Kenat,
Thanks for the information
