Bearing Limiting speed
I have a task for designing a shaft for a roundabout that is able to limit the speed, are there any bearing that can do that? or is there anyway to limit the speed of it turning?
RE: Bearing Limiting speed
You could try and use a centrifugal brake...
Best regards,
Sven
Does the shaft do work of some kind?
2 down, 18 to go.
regards,
Dan T
BTW, bearings that limit speed do not exist.
Gunnar Englund
www.gke.org
I understand that it seems like im just asking for people to do my work, I am simply asking for a point to the correct direction thanks
Walt
