Per Body Rendering Style?
The situation is this: I have an imported mesh-like human body upon which I create a wearable product. To clearly see the product, I choose the "Shaded with Edges" rendering style. The problem is, the human appears too complex with all the mesh lines (smooth edges). What I need is the human displayed using the smooth "Shaded" rendering style, but the product still using the "Shaded with Edges" rendering style. Is this possible?
Thanks.
NX11.0 Win10 64bit i7-3770K 16GB QuadroK2200
RE: Per Body Rendering Style?
I found a solution, which is to change the Emphasis settings under the Visualization preferences to remove the edges. However, for some reason, the de-emphasized geometry is translucent. The translucency slider only goes down to 30. Is it possible to make it opaque, yet still remove the edges?
Could you share your human body ?
It will be easer to help you
Didier Psaltopoulos
http://www.psi-cad.fr
There are plenty of other internet forums for that kind of activity smile smile
Do a search in this forum for JACK, some have posted some parasolid of a human body
